Ick!!!
well, measuring output of any amp goes a lot easier with a non-inductive dummy load, but those can be built from old hair dryers. If you have a DMM that measures AC voltage, you could probably use that to measure the output across the speaker leads acting as a dummy load.
You know you can probably get a much higher score with a 12" MT in a proper box?
Also if all you got is one somewhat questionable battery up front, thats not helping you.
lol ryan you are the king of obvious! lol although i dont really think you can get much higher than a 151 with a 12, i did do a 151 with my single 15. this was a test for things to come in the jimmy
. the battery insnt questionable it does what is is supposed to but u cant expect 650 amps from a small battery like that. i will be dropping to street c for the rest of the year.
