Ick!!!
Ick!!!
Well i won yesterday with a 148.5... i now have 2 15" mts and 2 MM4000.1s. so i gained .5 db by adding 8kw and another 15 lol im so ashamed... but i still won. my electricle system is the main problem with only 1 750cca battery it need serious help. (car cannot run in dbdrag). so what im gonna do is change to street c so i can put a battery in the back of my truck, and a battery under the hood.
unfortunatly i have some issues. i can only build up about 14 inchs from the floor of my truck. street c has to have the box below the windows in the car. either way im horrifyed by that score considering i did a 148 with one of each legal and a 151 in my driveway. but i did make my gf really sick with eminems go to sleep! she almost puked! i forgot how loud 148 is!
Hey Bill, a win is a win. I am sure you will figure it out. I was just outside tuning my system, the center channel still isn't done so I can't take it to a contest yet. But it will get there. I am planning on going to a show just about 100mi south of me that is a USAC 3x competition. I hope to do very well then.
Cant you add the batteries below the rear seat?
Just a thought...
Also I think theres a company called GMB or something like that. They make 8 Volt Batteries so you can get your voltage to 16V for comps
Trouble is you need them charged before you get there and its only good for a bit like all batteries...
Just a thought...
if you want to keep with one battery, switch the starter battery to a Kinetik 2400 before the event.
as for adding a second RE MT15, and 8Kw of power and only gaining half a dB, that sounds like you may hve an issue with cancellation or something.. if this is in a truck, you may also have a pressurization issue, which could be overcome by finding a place to vent (say, through the firewall behind the dash) the cabin to outside air without having to roll down any windows.
Otherwise, look at a battery isolator, and adding the Kinetik in back, as a dedicated audio battery if you do change classes.
well this main issue is no room under the hood. i have no room for anything bigger than what i have in there now. ryan 16v is now illegal in most sanctioning bodies in my classes. although some people stretch the rules and run 20+ volts. im probably gonna throw either an nsb90 or a kinetic 2400 monster in the back. i didnt gain match the amps i didnt have time but what is the best way to do that?
