needs some good, cheap subs (8's or a 10")
Yuppers. Those all were.
Right out of a cardboard box and just put your wires from amp to it.
I beg to differfalkenbd wrote:Still wanting to know what you makes you think something is SQ?
Again, the subs Bill linked are good, but with an 8" sub, you need more to acheive "SPL" remember. Its a cone area and displacement game... Fs also comes into play if you want to bang away on 20hz notes all day.
our 1508 has been documented and has hit 140+ db with 750 watts going to it. One 8 in a horn enclosure.
Cone area has something to do with it, but box has much more to do with it.
Don't think he can fit a horn enclosure in his single cab. what was the actual SPL and freq? I know a guy in Tennessee that did a 142.4 with a set of 6x9's in a horn loaded bandpass but it was at 80hz. The 1508's are bad ass speakers but it still an 8. I'm confused y the spl guys dont just use 8's if there just as loud lol.OnYrMrk wrote:I beg to differ
Well he has the limited space. I would suggest the T1508 for the space constraints. It is true that you need more 8's to equal the cone space that a pair of larger subs can make, but in this application, 10's may not be the best fit.
Let me get the information and I will post it up. it was measured in our mini..but I don't know the specifics.
Whats MSRP on those 8's? BTW?OnYrMrk wrote:Well he has the limited space. I would suggest the T1508 for the space constraints. It is true that you need more 8's to equal the cone space that a pair of larger subs can make, but in this application, 10's may not be the best fit.
dont mean to thread jack, but would those tang band woofers work well if i put them where my 6 1/2's are. (using them as rear fill)Bwcad1 wrote:4 of these
http://www.parts-express.com/pe/showdet ... er=264-854
or these
http://www.parts-express.com/pe/showdet ... er=295-200
- NorthQuad
hahaha, funny guy.Ryan from Ohio wrote:Yuppers. Those all were.
I meant this one... http://www.cadencestore.com/ProductCart ... roduct=523
Samplifoofer... right there.
dave.
