rca trouble.
rca trouble.
guys, my Premier 670 is giving me sub rca trouble.. the bass isnt as loud when its hooked up normal and when i take one of the rca's out, its just as loud with them both in, and when i hook one up and leave one out and touch the side of the rca input, it gets as loud as it should be.. is there anyway i can fix this? what about "grounding" my rca's? will that do the trick, and how do i go about doing it, ive tried other sets of RCA's.. this HU is really starting to piss me off..
here is a little video i made..i may make another since i had the volume down low and you may not be able to tell much.
http://s47.photobucket.com/albums/f200/ ... IM1481.flv
Solaced, i took your advice sort of..
first, here is a vid, you cant really hear, the volume was low, but when i touch the side of the input, the bass gets louder.. and when i stick it back it gets lower:
after that, i sort of did what you said, but i just took a piece of wire and wrapped it around the input on one of the preouts for the sub(to note, i cut the wire and you cant tell its wrapped around the preout now)
it works fine now, i have it on -1 and it beats.. but i dont like this "solution" so now its either a new alt or a new HU...
also, i know the RCA's arent in the right colored preouts, i just wanted to see if it made a difference before i did this wire thing, and it didnt, so dont worry i switched them around.
see that lil screw about a half inch away right under the antenna... try a lil piece grounded to that with a ring terminal... should work fine and will clean up the mess of more wires.
You could also try buying a set of grounded rcas
