how to connect my amp to my subs!
andrewn721
Post by andrewn721 »
http://myspace-568.vo.llnwd.net/01295/8 ... 7568_l.jpg
I have a JBL 1200.1@4ohm amp and i plan on using it to power my JL W3's d4. my subs are circuited as a parallel and has 4 plugs on the back. ([+-] [+-])/ my amp has 4 terminals (+-+-). i was wondering if i wanted to transmit 300 rms to each sub, how would i wire the amp to the sub. the image is how i think it is but im not sure. or maybe i am suppose to only use 2 terminals and have 2 wires in 1 pos terminal and 2 wires in 1 neg terminal. im not sure. how do i get 300 rms to each and what ohms should it be at?
thanks
brent
Post by brent »
You should wire your subs as shown below, and then just follow polarities into the amp. (pos to pos and neg to neg)
andrewn721
posting replys to make 10 min
andrewn721
heres a notehr message fsdkfhd
andrewn721
xfngrthjsrthrhffdfdfdfdfdfdfxc
andrewn721
one sec 2 sec 3 sec 4 how many toodles does itmake to make a noodle
andrewn721
shoodle boobdle bam noozle ice breakers SDSU
andrewn721
shibity shibity soooooooby nooooobi! 15 seconds
andrewn721
3 more to go then i can view ur atachment!
andrewn721
2 more to go then i can view ur atachment!!!!! i have to wait 15 seconds!
