POWER:
black/white - Source Ground
yellow - Battery(+)
black - Power Ground
blue/white - Auto Sensor
Speaker/High Leve Input:
gray-r spkr (-) gray/black-r spkr (+)
white-l spkr (-) white/black-l spkr (+)
Model No. A800 Amplifier:
12 volt negative ground use 2, 4, 8 ohm speakers.
Caution:
Do not connect right speaker negative (-) to left speaker negative (-) or to car body.(ground).
can anyone clear up the Power section.. and then the Caution part.. does that mean i cant ground it where the other amp is? i mean it says to not ground it to the car... or does that mean dont let any wires touch metal while hot? oh and how would i run this amp? just use an amp kit and connect the wires to the amp kit and run it regular?
oh and here are some pics.. and sorry they suck
i hope these pics helped...
