How To Wire Two...
- NorthQuad
How To Wire Two...
subs together when there are two separate outlets (I hope that's what they are called) on each side of the box and the amp is a 600.1 mono? The subs are Kicker Comp VR's 4ohm. So don't I have to go from amp to sub to sub? Also do I have to change wires around on the back of the subs? Thanks for any help.
no sorry i forgot about the dual voice coils...simply series wire the voice coils on each sub together for an 8 ohm load and then parallel wire the whole shebang back to the amp for 4 ohms...series wiring is in its simplest form in your case running a jumper from the positive of one voice coil to the negative of the other and then using the remaining positive and negative lead as if the sub had one voice coil...then to parallel wire the two together simply hook each positive and each negative up to the positive and negative connections on the amp...if the guy building your box knows that much he should be able to do the internal wiring for you so that your "outlets" (to borrow your term) will each be at 4 ohms...hope this helps i dont want you to blow your amp either..
- NorthQuad
Thanks for the info smoker. Man I've have had a crappy time with this system from the first day. A year ago until now I've paid $1700 for a system installed that has never worked and now I just wasted a few more hundred on new 12" Comp VR's that won't work the way I want them with my amp. If I were to try and trade these for dual 2ohm would they run at a 2ohm load on the amp or whatever? Sorry I don't know about all the ohm stuff.
- MobileAudio219
They're dvc subs, not svc.... He can either wire it to present a one or four ohm load to the amp....Darthness wrote:well.. 2 4 ohm subs will put a 2 ohm load on a sub in a parallel, and 8 ohms in a series, so you should be good?
this is according to the12volt's calculator
