did i make an ok choice
i just ordered a Boston Acoustics GT-2200 to power 2 Polk Audio MM840. i have my old eclipse pa5422 to power DLS X-Program X-SB62 i ordered. and a Alpine CDE-123 ??? any help would be great . i just bought a 2004 tundra. o and a q logic sub box.
- Chris from Washington
wow, nothing went wright. had to cut door panels to fit speakers and tweeters ( and i messed up on the cuts, gaps around speakers), one amp would not fit how i wanted under the seat. this is my first time doing this so i guess its natural for things to go wrong. i used 1/0 wire from battery with a 150 amp fuse to a splitter to two 4 gauge to amps. 4 gauge to ground. ran new 16 gauge speaker wires through doors, 12 gauge to subs.
Yep, things never go like you want them too.
For example, I had a fiberglass box for the Camaro. As I was restoring the car I added the power assist pull down motor. Now a couple years later I'm at the point where the car is on the road again, and I thought 'hey, I still have my old box might as well use it' Go to put it in. Doh, the pull down motor and new plastic interior piece sticks out further than the old one and the box doesn't fit now. I had to hack my box up and re-fiberglass it all.
What would have been a 5 minute drop in, took 2 weekends and trial and error to finally get it to fit.
