need advice on zx750.1 w/kicker comp box wiring
thinknoffcenter
hi all, kinda new to this car audio thing, so i have a quick question.
I just obtained a brand new sub/amp setup from a dude who owed me some cash. it consists of 2 kicker comp subs (here's a link) http://www.kicker.com/comp_subboxes
and a zx750.1 amp
now, i know the box is wired at 2 ohm load, and i also know that the box will only take 300 rms, but the amp puts out 750 rms at a 2 ohm load.
so is it safe to run it at these settings at like a lower gain setting or lower volume? should I rewire the box for an 8 ohm load and only get like 200 rms out of the amp? will that hurt it?
any help on this matter would be greatly appreciated.
thanks in advance
and a zx750.1 amp
thanks in advance
loudwagon15s
thinknoffcenter
ok, so i got the box rewired for 8 ohms, now, everytime i hook up the amp my fuses blow. i've tried hooking up the ground at the amp then the power and vise versa, and i've tried hooking up the amp and then hooking up the battery. what am i doing wrong? do i have a bad ground?
i'm grounded in the trunk, to a single sheet of paint free metal, with a nut and bolt.
Thanks
Thanks
thinknoffcenter
thinknoffcenter
absolutely. have a wire running from one neg terminal on one sub to the positive on the other sub, then the other positive running to the terminal, and the neg on the other to the terminal.
power wire is run from the battery, through the firewall w/ grommet to the trunk down the passenger side of the car (the side the battery is on). there is a 100 amp fuse about 8" from the battery.
thinknoffcenter
