speaker noise from amp
see thats the thing sometime that will work fine. it usually occurs if your RCA's run perpendicular to your power wires.
Bwcad1 wrote:see thats the thing sometime that will work fine. it usually occurs if your RCA's run perpendicular to your power wires.
Each one that I had to fix had them intertwined (so yeah totally criss crossed).
power and signal lines being together don't cause problems, but running the lines near things like ignition wiring or crossovers will.
i believe we went through this in a previous post. i have experienced it first hand in my truck. my rca's were layed over my power wire if i picked them up and away from my power wires the alt whine went away.
And I thought this was just Deja Vu :p
Richard Clark wrote a nice article debunking this myth.
as volume decreases enough to hear the noise, so does the current carried through the power wire, thus making any eminating field so minute, that it wouldn't have an audible effect on the system.
joeyc
Post by joeyc »
I still wouldn't want any unwanted noise, even if I can't hear it! lmao
JC's Customs
if you can't hear it, it isn't noise :)
\the definition of sound is the brain's interpretation of pressure on the tympanic membrane. remove the ears from the equation, and you have no sound.
Thus, if a tree falls in the forest, and nobody is there to hear it, it doesn't make a sound.
ok then explain to me what it was?
i think i got it now and im gonna have to side with glass on this one.....its early and i havent been drinking but if i understand glass correctly this is what happened....
some guy named clark (possibly clark griswald) cut down a tree in the forest and it landed on your car....since you werent there to see it and clark had his ears removed there was no noise. since there was no noise what you heard was not noise because you can hear noise and since you heard something that was quite obiously not noise you must not have heard it...see? its that simple
