1992 Jeep Wiring Diagram
dmeyer07
Post by dmeyer07 »
1992 Jeep Cherokee Laredo
Need the wiring diagram for the factory radio, trying to hook up an alpine to it, but the wires are not even close in color, so i have no idea what connects to what..
Thanks
-David
Go to best buy and buy a wiring harness, seriously you don't want to cut into the factory wiring if you don't have to. It will cost you $8 and save you a TON of time and possible problems down the line.
That being said, if you are still foolish enough to cut the factory wiring...
Constant 12V+ Red/White
Switched 12V+ Purple/White
Ground Black
Illumination Blue/Red
Dimmer Red/Black
Antenna Trigger Purple/Orange
Antenna Right Front
Front Speakers 5 1/4" Doors
Left Front (+) Gray
Left Front (-) Yellow
Right Front (+) White/Red
Right Front (-) Brown/Red
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Gray/White
Left Rear (-) Brown/White
Right Rear (+) White/Black
Right Rear (-) Brown
edit : I take no responsibility for this list. It is what my program says, I do not guarantee it is right. Use a multimeter and check the power wires to be safe.
dmeyer07
Post by dmeyer07 »
Justin from Detroit wrote:Go to best buy and buy a wiring harness, seriously you don't want to cut into the factory wiring if you don't have to. It will cost you $8 and save you a TON of time and possible problems down the line.
Ground Black
Dimmer Red/Black
Antenna Right Front
Left Front (+) Gray
it was kinda close, a couple of them matched up, but for the most part i just had to use a multi meter, thanks any way
-Dave
lancerswimmer89
Wiring
Post by lancerswimmer89 »
You might wanna try talking to Swimmerdude, i think he has a jeep of a similar year, and he might b able to hook u up.
