Lights are lights. You just aren't noticing your headlights - that says to me your dimming isn't even close to bad. Someone standing right in front of your car would probably notice a little.Dr. Bogger wrote:well first i want to point out that my headlights dont dim... just the interier lights do, but only a very little. Like my dome light, and my mirror light dim a little when pushing a lot of bass at high volume levels... But my headlights are fine.
But think about this - Why do lights dim? The answer couldn't be simpler:
ALL lights are brighter on 14.4v than they are on 12v.
When that hand-off from alt to batt happens, the lights are not as bright.
Try this - Turn your engine off, your lights will drop to the same level. Start the car back up - back to full brightness.
You just aren't noticing it with the headlights - that's more of a function of the violence of the dimming - yours isn't terribly dramatic, it's a sign that it's not really an issue. You'd notice if your amp was really SLAMMING your voltage down to the battery level, and further sucking the life out of it every time it did.
