Is it possible to blow an amp by pushing too much bass?
Dr. Bogger
Well... i just blew my amp this morning... it was a cheapy brand, powering 2 cheapy subs... the brand is "Dual".... I was listening to a bass mekanik song, as some of you know, that has a lot of powerfull bass, and when i turned up the volume up on my HU, the sub just stopped working... so i checked it out, and i think the amp is fryed... Has anyone ever heard of a amp doing that?
Welp, time to go back to best buy, and return it :P
before you return it, check your connections, it is possible you are running the amp at too low an impedance, so it went into protection mode. When you checked your amp, was there a metallic smell or electronics smoke odor around it. if there was, then something fried, if not, your amp was probably in protection mode. Also check your fuses too. You might have blown one also.
THis is why we try to steer people away from the inferior equipment.
Its not because we are rich and snooty (were not), its because we know better.
Now you do too!
Now you do too!
Dr. Bogger
Okay, well when i was looking it over, i didnt realy smell any oders... possibly a very slight order, but i only smelled it for a second... then it went away, so idk if that was the amp or not.
And i disconnected all the wires, and pluged them back in, and still no go, i checked all the fuses, and they were all still good. I turned the HU on and off multiple times, still no go... i dont know what the heck happend...
If it did go into protection mode, how would i get it out of protection mode?
And the subs are running at 4 ohm.
JeremyC, this setup is/was going to be only temperary, untill i got some extra money, and could afford a better setup.
Dr. Bogger
hmm.... that fuse i didnt check yet... but i did do a voltage test on the wires, and they all had power...
What i am going to do, is tomorrow morning, im going to install another amp i have laying around, and see if it works... if it dont, i know its something else, and not the amp. so hopefully i will get this all sorted out soon.
Thanks for the help everyone!
- Chris from Washington
Dr. Bogger
Yeah I know, I was just using something from your life, as an example.Dr. Bogger wrote:JeremyC, this setup is/was going to be only temperary, untill i got some extra money, and could afford a better setup.
I also pointed it out in case someone else in your situation comes on here lookin for help, and stumbles across the post. I would rather them have the full picture of why we say "spend a little more now, save a ton later".
Hay thats pretty catchy. I think I like that better than the watered down poop explanation.
