:help:
Need Help With My Audiobahn System
pcdipsetbg
I have an Audiobahn A18001DT Amp and i recently bought 2 audiobahn Alum10n subs to go with it, however when i hook them up and turn the radio on to test them they make a hissing sound then the amp goes into protection mode....does anyone know what is going on? do i have it wired wrong or is this amp not capable of powering these type of subs considering they are dual 6 ohm each? Please help!!!! I need to know if the amp will power these subs or not because if it will then i will just have to work witht the wiring or whatever is wrong but it will be a relief knowing i didnt buy the wrong equipment but i looked online and cannot find much information Please help!!!!
:help:
:help:
pcdipsetbg
pcdipsetbg
heres a diagram of how it looks, it not the best diagram but it gives an idea....
sub sub
l l---------- l ----l----------(+)AMP
l-------------------l----------------(-)
-=wire
(+)=positive
(-)=negative
have any diagrams or suggestions of how i can wire it?
sub sub
-=wire
(+)=positive
(-)=negative
pcdipsetbg
that didnt turn out how i wanted it to heres an explanation it has 4 positive and 4 negative on each sub i have the first 3 of each ran together like following i have positive wired into negative on first 3 then on the last i have the two positives left over on each sub wired together and ran to amps positive and the last negatives on each ran together to the amps negative
