Possible bad amp, need suggestions
The amp in question: Soundstream Van Gogh 800.5
The sub in question: Alpine 10inch TypeR 4+4ohm
Got it installed, and everything was fine for an hour. Then it started activating "Short circuit protection" mode on the amp, which means it kept resetting every second. When disconnecting the sub, everything was fine again. Got a new sub (exchanged), thinking that was the problem, and put the new one in. This one only lasted 5 minutes before doing the same thing.
Disconnected the RCAs for the main speakers, and found it still happening. Turned the gain to 0 for the sub, and it stopped. Adding any kind of gain caused it to cut off.
So...what the hell is happening? Bad amp, or something else? The wiring is correct, since the main speakers played for hours yesterday sans amp without a hitch.
If the amp is newer it should have some sort of warranty. Check into that first.
If not get an estimate. SOme places the estimate is free, others will charge you a minimum amount ($30-40). With this amp it may be worth having it checked.
6three6mafia6
