new components and sub
my in dash flip outs are din size....i can get 1/2 din dvd players i think for about 150 and flush mount tvs for about the same......not visor mounts really but with a reverse camera you could replace your rear view with it......
two4fifteen
Post by two4fifteen »
what brand are the 1/2 din dvd players
i can get a few, the ones i would recommend are absolute or microvision......not sure that microvision makes a 1/2 din but i know absolute does......we have been using them without a hitch, the monitors get a great picture and the dvd players work great...
there are a few out there that are pretty good like pyle believe it or not but micro and absolute seem to be the best that we have found so far....
two4fifteen
i changed my mind again....i just wanna upgrade my electrical system. I only have a month left for this work term, and thats all i want to finish up with. If you remember, i have this co-op thing at my college where i go to school for 3 months and then work in my respective field for 3 months, and so on. So i plan on getting a 200A alt and upgrading my big 3 to 4 gauge. Can any of you think of anything else i might need? And if i upgrade more in the future, like amps, how much power can a 200A alt handle??
im doin spl comps and im running somwhere around 2000+ watts running 12 speakers and a sub... u should be fine with a 200 amp... how big is you main power wire? i have a little light headlight flash and a little dash flash and about a .2 volt drop on major hits while im playin bass intesne music other than that im fine but since im planning more power im going to bump mine up to 275 amps for 100 bucks
two4fifteen
im also gunna upgarde from 4 to 0 guage for my main power wire running from my battery to my distribution block. Should my battery be okay, i believe i have a gold duralast, basically the next best one autozone had under the optima yellowtop.
yea the battery will be fine with an alternator that size go to excessive amperage thats what i have... how many watts total are you running?
two4fifteen
right now im only running about 1000w rms, between a kicker kx600.1 and a kicker kx350.4.
yea 200 will be plenty for you... contact nate at excessive amperage alternators tell him bill wolf from wolfpack audio sent you... what kind of car do you have?
two4fifteen
there's a place pretty close to me that sells them, justin told me about them. but i have a 2000 2 door 2.4L cavalier
