new components and sub
two4fifteen
Post by two4fifteen »
I finally got my new sub and components. I thought i might post some pics of everything, see what you think. forgive the sh!tty pictures, i used our 4 year old camera from work. and i still have to clean up the wiring from the amps, right now their both mounted to the back of the rear seat, and the wiring is everywhere...
sorry...im still trying to figure out how to post pics....
two4fifteen
i dont know why these wont show up....
it's easy, simply type [*img]http://www.PICLOCATIONHERE.COM[*/img]
Just do that, without the *'s
You can't upload from your hard drive, it has to be from a website. http://www.imageshack.com has free pic hosting.
two4fifteen
ill try that in a minute....until then, i was able to get it to work at another site http://forum.ecoustics.com/bbs/messages/4/178884.html
Another falls to the JL/RE bandwagon...
two4fifteen
lol sorry....i just couldnt turn down the sq and price of both. i only paid 750 for comps, kick panels, sub, and enclosure....... and they sound great
Not that its a bad bandwagon ;)
two4fifteen
and nobody else i know has either of them.... so from my friends standpoint is pretty original
im with justin but nice setup!
two4fifteen
hey justin, would you be up for building me a box for my alpine type-x 10. i still have it and want to put it in a small sealed enclosure because, for one, ive heard they sound awesome in sealed enclosures, two, i want something to put in my trunk when i dont want that huge box in their for that 12, and three, i dont wanna get rid of it. could you possibly pm me a price of a .65 cu. ft. sealed enclosure. i've looked everywhere for the subs displacement, but couldn't find it. here's the specs from alpine's website. Coil Height (Hvc) : 48.1mm
Cone Area (Sd) : 360sq. cm
D.C.Coil Resistance (Re) : 3.6ohm + 3.6ohm
Electrical Q (Qes) : 0.67
Equivalent Suspension Stiffness (Vas) : 17 liters(0.6cu.ft.)
Free Air Resonance (Fs) : 29Hz
Frequency Response : 24Hz - 200Hz
Gap Height (Hag) : 10mm
Impedance (Nominal) : 4ohm + 4ohm
Linear Excursion (X linear) : 19.1mm
Maximum Excursion (X peak) : 22mm
Mechanical Excursion (Peak-to-Peak) : 75mm
Mechanical Q (Qms) : 9.72
Sensitivity : 81 dB/W/M
Total Loudspeaker Q (Qts) : 0.63
Diaphragm Material : Carbon Fiber/Aluminum Honeycomb/Kevlar Reinforced Pulp
Magnetic Weight : 124oz.
Mounting Depth (top mount) : 218 mm (8.6")
Mounting Diameter (top mount) : 231 mm (9.1")
Recommended Box Types : Sealed/Vented/Bandpass
Recommended Sealed Box Volume : 0.5 – 1.0 cu. ft.
Spider Material : Nomex®
Voice Coil Diameter : 75 mm (3")
