Wiring Help
lost05
Wiring Help
Post by lost05 »
I want to run 2 1000w amps and 1 350 watt amp how do i set up the wiring? i want an amp for each sub and then i have an amp for my rear speakers any help would be perfect thanks
You could use a 3(if they make them) or 4 way distribution block.
Use something big, maybe 0 guage from the battery to the distribution block and then use something like 2 or 4 for the 1000 watt amps and using 8 on the smaller amp should be fine.
What subs are you running where you need 1000 watts a piece? I hope you plan on running a larger (much larger) alternator, bc thats a lot of power to be drawing.
tedd
lost05
Post by lost05 »
2 alpine type rs the amps are 600 watt rms
lost05
Post by lost05 »
and wouldnt it have to be a 4 way cause i have 1 coming in and 3 goin out
http://www.crutchfield.com/S-OlJJgpocWI ... I=211DBR44
something like that. 4 way refers to the amount of outputs it has.
tedd
dmeyer07
Post by dmeyer07 »
ridr4lif wrote:You could use a 3(if they make them) or 4 way distribution block.
tedd
Yes they do make 3 way distro blocks, they are often called a "T" block.
FYI :)
dmeyer07 wrote:Yes they do make 3 way distro blocks, they are often called a "T" block.
FYI :)
ahh...didnt know that. Thanks dmeyer.
"its a good day when you learn something." a smart old man once told me that
tedd
lost05
Post by lost05 »
thanks for all the help how much would an alternator like that cost and would a capacitor help at all until i but a new alt.!?
Not Really The Cap Wont Do Much You Should Just Us Save The Money To Get A New Alternator I Suggest Execessive Amperage Alternator
