how do you wire your headunit??
Tim
Post by Tim »
Just got to thinking and got curious how you all like to wire the headunit.
Do you: use crimp caps
Do you: solder the connections and heat shrink em (or use black tape)
or
Do you: just twist em together and hope for the best??
Just thought Id start a new thread,
I use crimp caps or solder and heat shrink.
Tim
Tim Strong
Email: [email protected]
X-box Live Gamertag:quad drpr
cool mr grinch
Post by cool mr grinch »
i normally use heat shrink butt connectors.
James-aka-Cool Mr Grinch
i use crimp caps, butt connectors are less reliable because teh wire does not get twisted first. so now one connectioin becomes like 3, id use just tape before using butt connectors....chain, weakest link thing, you get the pic
Solder and heat shrink only.
As smoker points out, butt connectors suck nuts. I had an issue long ago with them and wont use them anymore.
The crimp caps wouldnt be to bad, but I like the security of the solder.
the reality of it is that twist and tape is as secure as anything as long as you strip enough wire to twist it securly....but the crimp caps are quicker than using tape on every connection....
loudwagon15s
Post by loudwagon15s »
i used to have problems with butt connectors, but then i found an old pair of crimping pliers in my dad's toolbox which really get a good crimp with lots of pressure and havn't had a problem since. Solder can be a pain sometimes
scotts1000rr
Post by scotts1000rr »
smoker wrote:the reality of it is that twist and tape is as secure as anything as long as you strip enough wire to twist it securly....but the crimp caps are quicker than using tape on every connection....
And if you split the wire,It wont come apart.
cool mr grinch
could somebody explain crimp caps?
i use heat shrink glue lined butt connectors. i've never had a problem.
scotts1000rr
http://www.idealindustries.com/media/img/products/wire_termination/product/crimp_splice_cap_insulator.jpg
cool mr grinch wrote:could somebody explain crimp caps?
I use crimp cap's but soldier everything else. i used to use butt connectors and if i do its the heat shrink version.
