Pioneer GM-5300T
loudwagon15s
i'd highly recommend making your own box with aeroports such as these:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=268-350
2 cubic foot with 2 3'' aeroports would bring the tuning to roughly 34-35 hz.
Just make sure that everything inside the box is at least 3'' away from anything else
loudwagon15s
it depends a lot upon what kind of car, and how much room you have to work with, sub back, port back generally works well in a trunk, while sub up, port back works well with a suv, or similar. The box could be individually chambered with each sub having its own port, but IMO, for your setup, its no big deal whether you do or dont
explain to me y its the loudest design in street cars right now? these guys are doing 160s with 2 12s. 159 with 2 10s in this kind of box. 9/10 loudest cars in dbdrag fire sub forward in a round tube with a six or 8 inch aero port out the back.JeremyC wrote:Thats pretty normal. With the subs firing foward part of the wave is being reflected, and then causing cancelation. If you look at the faq section there are some pictures explaining it.
I beleive the topic is )why does my stereo sound louder with the windows down.)
but to the op. sub forward port back is really only for spl purposes. do sub up port back and deaden the car. also when you fire tword the rear of the car the wave is elongated although minimal it sometimes does make a noticeable improvement in spl levels.
Sounds like cancelation to me bill. But I'm guessing he is listening to more than one freq at a time.Battousai wrote: Thing is when the subs are facing the front it doesnt hit as hard as when the subs are facing the back.
And yes it is normal. Sure there are ways around it, and its not going to happen at every freq that the speakers play. Only the ones that are reflected 180 deg out of phase.
