Ok I know there are a few people on here who have worked with Lexan on before so here is my question. What is the easiest way to cut the stuff. I need to cut an oval out of a 4'X8' 1/2in thick piece and really don't want to screw it up. At damn near $500.00 it would really suck!! :help: I was thinking a jig saw but what type of blade would be used?? If you guys have any tips or suggestions it would be greatly appreciated.
I use a dremel with a spiral cut bit (rotozip bit) made for cutting plastics... at higher speed it melts through it like butter, then just some light sanding on the edges.
i dont know where its at for 100 bucks, i have an account to buy it direct from a local supplier and it runs at least that, in fact if he got lexan instead of plex thats a good price...
i got my prices mixed up but even then for basically the same thing with no name brand (lexan is the name brand) i can get a 4'x4'x.25 piece for 106 i just checked it.
It is Lexan but I had to go with it because Plexi didn't have a high enough heat rating. The piece will be subjected to 80C for prolonged periods of time and cannot warp. Work is footing the bill for it but I shopped around and this was the best price I could find.
gotcha. like i said if thats the case take it to a place that will water jet it. its the best way of cutting it period and they may charge you 40 bucks.
Just thinking about it, I'd probably cut out the piece you want in 1/2 or 1/4 mdf first to get the shape exactly how you want it, then use that as a template with a router or rotozip or whatever to get the exact shape. This way you should make your mistakes on the cheap wood rather then your $500 piece of plastic. lol.
