Hifonics or MA audio
Post by audiobass10 »
I plan on purchasing 2 12" soundstream tarantula dvc 1 ohm subs and i need to know whether it would be better to run them off of Hifonics Brutus BX1800D mono amplifier (1x1800wrms@1 ohm) or an MA Audio HK401SX ([email protected] ohm). Keep in mind i plan on wiring the subs in parallel configuration and each sub is 900wrms. I'm not sure if both of those amps would work for me or not because i've never owned 1 ohm subs before and i'm unsure if i need the amp@1ohm or @.5ohm with the 1 ohm subs wired parallel. Please help me decide which amp i should use and how i should wire them. Id really appreciate it.
Go for MTX or RF. Those are both equally bad.
I can't find a good price on an mtx amp to power my subs. Do you konw of any good amps that will run them for a decent price??
I really recommend against Hifonics because it is nothing more than an Audiobahn; inexpensive flashy paperweights. I've read numerous articles about them failing for no reason within a year. MA Audio is almost like that. I believe they'd be only slightly better.
I don't mean to burst your bubble, but good ones cost money unforunately. How much were you looking at spending?
You can look at the last model JBL amplifiers on eBay. The JBL BP1200.1 would suit you nicely. That should be had for as cheap as you are looking for (somewhere around $200 on ebay?)
That amp has been suggested to me by two people so ill check it out. Actually i my budget is about 400. The MA audio amp i was plannin on buyin is 409 but i'll check out the JBL first.
Thanks
diceman1000
Post by diceman1000 »
i agree that ma and hifonics are crap,but stay away from rf as well...you could check out the elemental designs nine.1,it is 1200 rms at 1ohm,you'd have to call eD and ask,but i'm pretty sure it will run safely at .5ohm also,it is only $350 shipped and has a 3 yr. warranty
Damon
expect the worst,hope for the best,and take it as it comes...live life to the fullest,alway cherish your family and friends,especialy your wife and kids
HU:ECLIPSE CD8051
FS:CDT CL61A's
F.AMP:MONITOR 1 MK2.70
RS:N/A
SUBS:TWO eD 13Kv2's in 1.25 cubes ea.,sealed
SUB AMP:CROSSFIRE BMF600D@1 OHM
WIRING:SCOCHE EFX,STREETWIREZ
CAP:STINGER 1 FARAD
BATT.:OPTIMA YELLOW TOP :sub: :sub:
