Help!!!!!!
wykydjuggalo
Help!!!!!!
I have a crunch pzi2250 amp hooked to 2 pyramid 700watt 10's, i just hooked it up today, I've had the amp for quite a while now and never had any problems out of it until now. The amp is getting power but the subs aren't working. i can't figure out why. i know the subs work i connected them to a friends amp and they worked fine. any help would be appreciated.
start by checking your RCAs and remote wire
wykydjuggalo
wykydjuggalo
Have ya checked the output(s) on the amp with a dmm?
And no it wouldn't, sorry just got up and didn't quite register till after I typed it
wykydjuggalo
Read the how to set gains with a dmm in the FAQ threads: http://www.caraudiocentral.net/forums/showthread.php?p=91950#post91950 check using AC Volts 1)probe positive 1) probe negative... and double check your ground... You may have enough of a ground to power it up, but not enough to support it, is it going into protect or just not doing anything?
wykydjuggalo
wykydjuggalo
