I'm letting my cousin use my old amp and it isnt getting any power.
We checked the ground and that is fine, the fuse isnt blown on anything, and the power cord seems to be fine.
There is 2 remote outputs coming out of the cd player, but none of those work.
What else is there to look for?
(The amp was just used on Friday, works perfect)
Amp Power Issue
brisgreat1
check the amps fuse, fuse in power line, snad that ground real well and if that doesnt work try another ground so that your sure it isnt the ground. make sure rem, ground, speaker wire and rcas are plugged in and working. as far as head unit problems i think certain problems occur towards certain brands and models so more info could be nice i guess. if the amp was working recently then id say its the ground, wiring or head unit... all should be a quick fix though.
