4ohm load?
jaysway1005
- Member
4ohm load?
how do you make a dual voice coil sub run @ 4ohms???
- swimmerdude
You need either a single 4ohm sub or a dual 2ohm sub. The single 4ohm sub will be just posotive on sub to posotive on amp and the same for the negative. For a dual 2ohm sub, you wire the sub in series..... which can be seen here http://www.rockfordfosgate.com/rftech/w ... C_4ohm.gif
