need help badly
need help badly
i have the dumbest mother in the world and she decided to jump start another car with my 2001 jeep grand cherokee i have an alpine cda 9833 the audiobahn flame q capacitor with built in dist block a ppi dcx 1500x1 for my subs and a ppi dcx 1000x4 for my highs my subs are jl audio 10 w 6s 4 of them so she called me at work and broke the news to me, nothings working ALL OF A SUDDEN, and of course it wasnt her fault, she didnt shut the radio off before she jumped the other car. i heard a whining from my capacitor and the amps and volts meters where jumpings all around but maxing out at 12 volts and about 8 amps. i took the cap out put in dist blocks to bypass the whole cap to see if that was the problem but it didnt work, the volume was on for 2 min then self lowered itself to no sound at all. i tried swapping out the radios but that didnt work either any help id appreciate it a million times over thanks alot.
Honestly, if the system was hooked up correctly, then jump starting another car battery to battery wouldn't have damaged your system. I would start looking at your install before jumping to conclusions that your mother was at fault first.
I would check the fuses first, each and everyone of them.
Dont forget to check the cars fuses in the fuses box...
subster87
is your radio hooked directly to your battery or something? or is it wired right? yeah did she hook black to red and red to black or what? change out your battery if your current draw is going wild, check make sure she didnt hit your power cable under the hood or knock a ground loose. Yea like they said alllll the fuses! please tell me with good expensive equipment you did jerry rig all your wiring, not to sound mean but thats what it seems like.
