Atomic AT-2200.1
Atomic AT-2200.1
Does anyone have experience with these amps. Do they put out the rated 2200 RMS @ 1 ohm and how reliable and durable are they. And what is up with the ruse rating? It is only fused at 120A and i do not know if it is just me but for a 2200RMS amp shouldn't it be fused around 200-300A. I do not see how it can do rated power be fused that low. So if anyone has any information/experience with these particular amps please let me know if they are decent. As i said i just want to know how they operate on a 12v system and if they do rated power or not and just overall if the amp is decent or not. If not hit me up with some suggestions of amps that will do 2000-2500RMS that i can get BNIB with full manufacturers warranty for $700 or cheaper per amp.
toomanyamps
toomanyamps
I have heard of other bad dealings as well, and have not dealt with them personally, but here's on to consider
Massive Audio P3000.1
Check it out here:http://www.massiveaudio.com/lowband/products/amplifiers/pro/p3000.html
And yes I am an authorized dealer for Massive :)
toomanyamps
Well like I said if you gonna go the route with Atomic be carefull cause you probably will get fizzuked.....Massive Audio I know nothing about....But I do know most amp companies out there these days do not push the wattage they say they do.....If you are looking for a powerhouse amp I have an old school Us Amps VLX-400 and a 4000X.....They are both very powerfull and great for comp....I would do the 4000X for 550 and the VLX-400 for 750....Good luck with your search
CEA is trying to fix all that... If you see that the amps are "CEA Compliant" then they are rated that in RMS not max... and yes all Massive Amps are CEA compliant (one of the reasons I picked up Massive)toomanyamps wrote:But I do know most amp companies out there these days do not push the wattage they say they do
Retail on the Massive P3000.1 is $879.95, Massive lists them on their online store for $791.96, I sell them for $660.00 plus shipping.
Alphasonik is supposedly rated power, but not CEA rated... I imagine you are probably looking at the PMA1200DA with the 2470wrms @ 1ohm... That one retail's for $1000.00 and can be found for cheap at alot of places online, but be careful as most of them are not actually authorized dealers as alphasonik does not allow internet sales... If you check out their website you can see all of the companies online that claim to be but really aren't... and with that you get NO factory warranty, so be careful.
