Hey Kiki
well at the moment the car is taken apart. I'm chemical stripping it at present before doing some body work, shaving handles and locks, etc.. then priming it, skim coating the entire car, and then block sanding it.
after that it gets primered, sanded again, and shot with paint.
as that's getting done, I'll be pulling the motor and tranny for a rebuild this winter.
crzystng
- Member
damn soundz like you got your hands full!! I was recently informed that you had put a system in there and I knew nothing bout it, but then again Ihavent been on in quite some time too!! but from the equipment listed it soundz to be a killer setup!! as usually from you!!
btw what color are you going to paint it?
I had the system in but not permanently. The car was due to be taken apart anyway so the interior is the last part I'll do the finishing work on.
I'm still deciding between a flat blue (similar to the blue ford falcon they did on Overhaulin') or a deep candy blue.
it'll essentially look like the picture on the front page of my site.
http://www.wickedcases.com
