InterFire IF4700?
Audiophile
InterFire IF4700?
Post by Audiophile »
Does anyone know where I can find specs on this amp? I tried google searching and came up rather short. Any help is greatly appreciated :)
~BrandoN~
Audiophile wrote:Does anyone know where I can find specs on this amp? I tried google searching and came up rather short. Any help is greatly appreciated :)
~BrandoN~
Well there's the problem right there. It's a Interfire A700.4 not the other way around :p
I'll save you the trouble though here's the link:http://www.interfireaudio.com/ampsAB.html#45chan
Audiophile
Hmmm...see I thought that might be somewhat relevant, but it's not the same amp. The one I have seems to be an older model...I'll go take a pic :)
Audiophile
Ok this poses a new problem, that's an old school amp, predating any online records... I'm assuming it still works for you to even be asking about it.
As much as I hate to say it I don't have a clue... Best assumption is only the obvious of it being a 700w 4ch. and the Mosfet definately tells you it's an A/B amp from the earlier era.
Did you try getting a hold of Interfire yet, cause I'm sure they have some records of it buried somewhere.
Audiophile
I figured it was old school. And no, it doesn't work anymore--I picked it up for free from a guy I know. As soon as it turns on (yes it gets power) it goes into protection mode immediately.
I'll try getting ahold of interfire, that's actually a good idea :) I'll keep you updated on how that goes.
Thanks for the help Cargodz!!!
~BrandoN~
I wasn't much help, but good luck :)
OnYrMrk
Post by OnYrMrk »
Run away Forrest...Run!!! It might be old school, but hardly worth your money to get it fixed, unless you are the one doing the fixing. I personally wouldn't give it a thought....I would just toss it, but then again, I am shallow like that.
