Sony Xpod 480 Watt Amp
Darolla
Post by Darolla »
Wuz up yall I REALLY need help becaue im just about to give up on this beat thing. I got another amp the sony xplod 480 one from a pawn shop so I assume that its working hooked it up and everything was fine, but everytime I turned the volume up the subs would go off and come back on so I assumed that I needed a new battery because the car wouldnt start up sometimes either. Anyway I went to auto zone bought a new battery and soon as I turned the amp on it started playing for like 5 seconds then it shut off and wont come back on whats the problem?? I am using a 60 fuse. Also when I hook up my broken amp the light comes on, but when I hook up the sony one again the light doesnt even come on. I dont think its blown becaue I just got it and I only played it for a total of 5 mins can anyone help????
Yes,
That amp is a piece of shit.
Sorry, but I had to tell ya.
Anyways how do you know the amps good?
Maybe you blew your subs out? And that is causing the amps to fry? Happened to me before...
Post by audiobass10 »
Well you already got 5 minutes of use from that explode amp. How much more can you expect? :scorp:
Darolla
Post by Darolla »
So was that a bad amp to begin with? What do I do? Will it ever come back on?
60 amp fuse is probably too much and cooked the sucker
Darolla
Post by Darolla »
I figured that so what size fuse I need? And if I get that size will the amp come back on because with the first broken amp I put a 40 fuse on it and it wouldnt come on but when I put the 60 fuse it worked. I only have 1 sub bridged I forgot to mention that.
Darolla wrote:So was that a bad amp to begin with?
Throw it away
Darolla
Post by Darolla »
So what kind of amp do i need I have one MTX 675 12 bridged?
two4fifteen
Post by two4fifteen »
and how did you "bridge" the sub?
Darolla
Post by Darolla »
I used the positive side from the L speaker and the negative side for the R speaker
