HU subwoofer option
Evanjl
HU subwoofer option
Post by Evanjl »
my head unit has a subwoofer option and all it is is a wire with an rca plug in end on it. if there were two ends i would thing that it would be used to go to an amp but there is just one....how do i convert this one end to power holpfully like an 8 inch sub..
if that made any sense at all
You can either just use that single one or you can get a Y wire to split that single one into two.
Evanjl
Post by Evanjl »
do you think it would be better to run my amp and subs off of this rca rather than the ones i am
I don't know what RCAs you're running your sub from, you need to clarify. Are you currently running your sub amp off of that single RCA channel or are you splitting them and getting two channels out of it?
Evanjl
Post by Evanjl »
my head unit has frount and rear rcas which each have two rca ends then one end rca labled subwoofer. at the moment i am running my amp off the rear rca cables
two4fifteen
Post by two4fifteen »
thats because a subwoofer doesnt need a stereo (left and right) signal
If you're not running any other amp off your rear RCA outs, just use that.
