What amp should I buy to push 2 Kicker 10L7
SpiderCoder
Post by SpiderCoder »
I can buy a used xtant x1001 for 350.00 or I can buy a JBL 1200 watt used for around 175. I believe this is the old style JBL 1200 watt monoblock help please.
What would be the benefits over one another
two4fifteen
Post by two4fifteen »
at the very least, here's what they both look like where it counts.
http://ampguts.realmofexcursion.com/Xtant_X1001/
http://ampguts.realmofexcursion.com/JBL_BP1200.1/
xtant is generally looked upon as higher quality than non-crown made jbl. it would probably last longer and have higher quality components. but jbl is still a good brand. if money is an issue, its a good option for you.
you could buy my elevation xs125.4 for 250
SpiderCoder
Why would I buy that amp
for two kicker 10L7 ????
joeyc
Post by joeyc »
it will put out 500 x 2 @ 4 ohms
JC's Customs
yes sir it certainly will
two4fifteen
SpiderCoder wrote:for two kicker 10L7 ????
because it puts out as much power as those others, and if you were gunna go with a 1 ohm load, changing to a 4 ohm load shouldn't be a problem. and its a good amp.
joeyc
Post by joeyc »
I have one myself, great amp!
JC's Customs
SpiderCoder
I went with the xtant
SpiderCoder
no I got dual two ohm so Ill be putting ot a two ohm load thats why I went with the xtant
