why doesnt my dash light up now?
Hey guys...I just finished putting my HU in my glove box...screwed the glove box back in. Then I put the stock CD player back in the dash hole for the deck, and that was about that. For some reason now when I switch my lights on, my lights will turn on, but my dash won't light up. Not only will the speedomoter section not light up, but the actual dash with the A/C buttons and all won't light up.
Any ideas? I checked all the fuses and they're fine. Anything else I can check? Can't drive at night at the moment so if you even have a guess throw it out there so I can check. Thanks.
- MobileAudio219
taillights working? i'd get a test light and check the fuses while they are in the fuse panel with the key on...
kevinberry1
Chris from MI
Yeah my guess would be a wire got pulled loose somewhere behind the dash. Especially if your fuses are all still good. Make sure you check the fuse box onder the hood also not just the one in the car. Just throwing some ideas out there.kevinberry1 wrote:If it isn't a fuse I would guess that one of the factory wire harnesses is loose or disconnected.
Have the same problem in the BUick since I bought it.
Ended up getting some LED projectors and pointing in on that stuff.
Never tracked down the actual problem although I suspect it to be a bad wire somewhere as the fuse always blows.
- MobileAudio219
Thats a fire waiting to happen, its blowing the fuse for a reason. Do yourself a favor and put the right size fuse back in and fix the problem the right way.JL Man wrote:i had to put a bigger fuse in it
