Dvc
duff5555
Dvc
Post by duff5555 »
G'day
jus been lookin at upgrading my system mainly my subs, i don't know heaps bout dual voice coil subs and was wondering if someone could give me their opinion on what they think.
What would be the difference, if any between the following 2 setups:
1. Having a 2+2 Ohm dvc sub wired in series to make a 4 Ohm load
2. Having a 4+4 Ohm dvc sub wired in parallel to produce a 4 Ohm load as well
Would there be any in the sound between set ups, or is the main point of 2+2 DVC subs to allow you to wire your sub the your amp in a 1 Ohm load (providing the amp is 1 Ohm stable).
Any feedback would be greatly appreciated.
Thanks
Mercedesbends69
Post by Mercedesbends69 »
Two 4 ohm coils in parallel will give you 2 ohms, not 4. DVC Subs' only purpose is to give you more wiring flexibility, a sub will not sound different because it has a different impedance than another.
duff5555
Post by duff5555 »
oops yep ur rite 2 Ohms, maybe i was thinkin dual 8 :happy055: cool thanks . So its purely for more wiring options,
thanks for your help
Its main purpose is wiring options.
However check all specs thouroughly.
Sometimes you can gain/loose xmax between SVC and DVC subs.
Mercedesbends69
Yeah actually now that I think about it, I can think of one case where xmax varies according to impedance: JL's 12W3v2's come with different Xmax's based on impedance.
