I got a new jvc kd-sh909 which has front/rear/sub. I'm using front/sub outputs with a JL 450/4. Everything works fine when using front or sub individually.
However, when you connect all four RCAs, the signal appears to bleed through. The subwoofer channels receive signal from the front channels. So when you turn subwoofer level to 0, there is no effect. I've checked that the rca's are connected to the right channels.
Anyone heard of something like this? I've run out of things to check.
