2 channel or mono amp? for 1 Premier subwoofer(ts-sw1241d)
Hi there, I just bought a pioneer premier 12" subwoofer(ts-sw1241d). It is a 4 ohm single voice coil(since it has only 2 terminals-1 pos. and 1 neg.,Right?)and it has an RMS rating of 350 watts. Was wondering which type of amp to power this single subwoofer.--2 channel or mono? Any input would be greatly appreciated.
- swimmerdude
You could actually go either way. If you got a 2-channel amp, you want the amp to put out around 350rms bridged at 4ohm and maybe in the future if you upgrade your system, you could use the amp for speakers up front. The other way to go is to get a mono block class D amp. Again, the amp would need to put out around 350rms at 4ohm.
two4fifteen
two4fifteen
- swimmerdude
Actaully he is kinda right.
When you bridge a 2 chanel amp, the amp sees half the current load (this is how you get the added output). So if your running a single 4 ohm sub bridged on a 2 chanel amp, the amp actually sees a 2 ohm load.
Thats why some amps say, 2 ohm stereo stable, but not 2 ohm bridged. Because 2 ohms bridged would actually make the amp see a 1 ohm load.
EDIT: No this doesn't mean you need an amp thats stable at 2 ohms bridged. Just make sure its stable at 4 ohms bridged (most are). The manufactor should have figured out the rest for you.
two4fifteen
O.K. -Thanks for the input guys. I have MB Quart components in the front doors and MB Quart 2-ways in the rear doors powered by a U.S. Acoustics 4 channel amp. I got the subwoofer and was looking at the Hifonics amps to power this sub in a sealed box that I custom made. The hifonics brutus series(mono) and zeus series(2 channel). Maybe I'll go with a Zeus 2 channel because they are a little easier on my pocketbook and they will put out more power with my set-up. This site is awesome, glad I talked to you guys before I went out and bought the wrong amp!
