Some wiring / speaker wattage questions
Couple of questions folks:
1. For 8 ohm speakers that are going to be drawing power from a 4 ohm amplifier, does it need to be wired differently?
2. I see a couple of posts about giving extra wattage to speakers which results in a increase in db levels. On the flip side, if I am not after SPL, is there is a minimum amount of power that is required for the speakers to sound optimal? I read somewhere else that tweeters at 15 watts can generate quite a load db-wise. Having extra headroom is always a good thing I suppose, but what would be a rough minimal gauge for it to sound optimal?
Ohms reffers to what an amp will see, which will vary depending on how you wire.
So if your speakers are 8 Ohms and ytou run each one into the amp thats what the amp will see. Likewise if you amp is rated @ 100 WRMS into 4 Ohms and you give it 8 Ohms the power output will drop to 50 WRMS...
You usually want to give speakers about 70-90% of rated power.
If you wire them together in series it will bring the impedance on the amp down to 4 ohms.
Still dont know how to post pics.lol
http://www.rockfordfosgate.com/home/
^^ This site can help you with wiring them together.
