Advice on 12" sub for nice budget system
Hi guys,
I'm thinking of doing a nice budget setup for a friend.
I just wanna do one 4-ch amp, 2ch for comps, 2 bridged mono for 1 sub.
I was looking at Kicker kx600.4(a) or sx700.4(b).
Comps, i'm thinking Infinity Kappa Perfects, so they'll be getting 75wrms(a) or 82wrms(b).
For the sub, thats what i'm unsure on. I like the RE SE 12", but its dual 4ohm so its a no-no (dont want 2).
Power to the sub will be either 300wrms(a) or 325wrms(b).
I need a dual 2ohm sub, and 12" size.
I will prob go with option (a), as (b) will be too much $$$.
Any suggestion on a dual 2ohm, 12", achievable optimal output at around 300wrms (gonna make suitable ported box), great SPL (but gd quality also) sub!???
Any advice much appreciated.
Kappa perfect would be a pretty good choice for comps.
As for a sub, check out Diamone audio. Here's a link to one:
http://www.woofersetc.com/index.cfm?fus ... ct_ID=2841
Its 400 rms, but im sure in ported it could get loud w. only 300.
Another good choice is the JL Audio W3V2:
http://www.woofersetc.com/index.cfm?fus ... ct_ID=2062
Could also look into a 3 channel amp. I dno about the kicker kx550.3, but it MIGHT be stable to 2 ohm on the woofer channel. Worth lookin at.
Robert Wollenberg
Why isn't 40 wrms enough?chodecz wrote:only 2x40wrms for the comps isnt enough![]()
Robert R. Wollenberg
Audio Alchemy, Owner
Phone: (325) 480-2790
E-mail: [email protected]
Web: www.audiochemy.com
www.abilenecaraudio.com
www.abilenecaralarms.com
It is mroe of like 60 Watts RMS. Assuming that your car is in between those voltage ratings. I went with JL XR650CSi, but they are like $300 components. Maybe go with some CDT CL-61A, I've heard some godo things.
RMS Power Ratings:
14.4V:
70 watts x 2 chan. @ 4 ohms
85 watts x 2 chan. @ 2 ohms
Sub Power:
210 watts x 1 chan. @ 4 ohms
420 watts x 1 chan. @ 2 ohms
12.5V:
40 watts x 2 chan. @ 4 ohms
70 watts x 2 chan. @ 2 ohms
Sub Power:
180 watts x 1 chan. @ 4 ohms
360 watts x 1 chan. @ 2 ohms
RMS Power Ratings:
14.4V:
Sub Power:
12.5V:
Sub Power:
Robert Wollenberg
The difference between 40 wrms and 60 wrms is roughly 2 db.
Also, I'm pretty sure headroom isn't associated with how many watts an amp produces. An amp either has it or not and you either chose to use it or not by setting your gains properly.
