tweeter noise
neumann
tweeter noise
ok here's the situation, i just installed my components and amp, there is one problem though, i am getting this static like noise comming from the tweeters. It is present when the voume is all the way down at zero, and it increases as i increase the volume.
Does anyone know what this could be and how i could fix this?
i hooked up the amp using the high level inputs, could i be getting a poor signal because i hooked it up with these?
help me please
help me please
neumann
the manual said that the hu didnt have rca's, then once we took it off, surprise, it had one pair. That was after hooking it up with the high levels, so the plan was to use the high levels for the front channels and rca's for the rear, looks like im changing that now. Either rca's for the front channel and high levels for the rear, or im just going to use y splits.
Robert Wollenberg
I'd use spliters and run RCAs only. Scrap the high level all together.
Robert R. Wollenberg
Audio Alchemy, Owner
Phone: (325) 480-2790
E-mail: [email protected]
Web: www.audiochemy.com
www.abilenecaraudio.com
www.abilenecaralarms.com
