freq. filters
JL Man
freq. filters
Post by JL Man »
on my amp it has frequency filters, so if i have the hp channels set to 250hz, is will allow 250hz and below go to my comps? my lp is set at 75hz.
High Pass = all frequencies above the selected will go to the speaker
Low Pass = all frequencies below the selected will go to the speaker
Unless you've got some really good speakers, you don't want anything below 75 Hz going to your main speakers. Similarly with subs, you don't want anything above 100 Hz coming through them. (generally speaking)
You won't need both the hp and lp set, the switch can only select one at a time (unless you also have the HP+LP switch). You will never want both switched on unless it is a special case.
