ohms in the real world
sonso_chi
Post by sonso_chi »
looking into new system, does it really matter if I run a system (amp n subs) at 1 vs 2 ohms?
In what way does it matter provided I get good stuff.
I can get two 4ohm comp vrs and run them at 1ohm
or two 2ohm and run them at 2ohm
If I choose the prior, I can get a good amp (kicker, mtx, Hifonics) to power them at 1ohm that would be cheaper then having to get a good amp that can give them as much power at 2ohm load
i'm trying to make the smartest move ($), I only intend on having this system for 5 years max. so, when it comes down to it, what advantage is there to running the system at 2 ohms?
Thank you
JL Man
Post by JL Man »
i believe it is the higher the ohm load the clearer, but dont hold me to it. if i was you i get the vr's and save some dollars. they are good subs
No ohms will not produce any diff sound. 1, 2, 4, ohms wont sound any diff them 8 or say 16 ohms. They make diff ohm subs so you can wire them at ohm loads you need. As for the 5 years thing. I have never owned a system for longer then a year. So good luck with that.
JL Man
Post by JL Man »
see i told ya dont hold me to it, lol . . yeah i know, i've been thru 4 sets of subs, 4 amps, and 5 hu in 3 years
Which adds up to big $$$$ If I could take back all the money I ever spent on this...Man I'd be rich, but F that, I wanna be heard :)
JL Man
Post by JL Man »
hell yeah, i would have started off with some re xxx 18s, something huge and loud!!!
NViejeP
Post by NViejeP »
Out of curiosity what happened?
Needed to upgrade or they broke?
JL Man
Post by JL Man »
well the 1st the comp vrs got ruined when i totaled my car, 2nd the solo-barics kept blowing tinsel wires, 3rd the audiobahn sucked butt, and now im currently with my w3s, amp changed as i got new subs, hu's i just upgraded as i went along
sonso_chi
Post by sonso_chi »
JL Man wrote:well the 1st the comp vrs got ruined when i totaled my car, 2nd the solo-barics kept blowing tinsel wires, 3rd the audiobahn sucked butt, and now im currently with my w3s, amp changed as i got new subs, hu's i just upgraded as i went along
i had the same system for 3 years until i wrecked my car and am now updating.
i've had insufficient funds and lack of time, but that will all change in about 3-5 years. Then I'll get some real stuff...
but from the feedback I'm getting it sounds like I should just go with a 1ohm load given I want to get two subs and powering them that way with my amp optioins will be cheaper....
thanks :thumbsup
i may actually go with a HiFonics amp (new model) instead of Kicker zmp and save some more money.
I'm having a hard time figuring out if I want to go louder, I am comtemplating getting two 10" CVX's
I'll have to figure that out...
in the past when I was changing my system a lot, I remember getting some 12w3's and they sounded wondeful but didn't hit hard enough for me.....
but my RF H2's hit hard but didnt sound that beautiful (in my sealed setup)...
I know I ramble a lot
JL Man
Post by JL Man »
with the 10s and a hifonics amp its like a $500 system . . not bad, my w3s are running off my rear 4-channel channels (75 watts each) and turned up they slam.
