My Sub choices, cant make up my mind
BigMack6933
Post by BigMack6933 »
Here are the choices I like, Starting with the ones I like most but The subs will be going in a 99-04 mustang, either IB or just a ported box firing into the cab...
One and will upgrade to a pair JL Audio 13W1v2-4
Two Pioneer TS-W306 12''
One Hifonics AS12SQ 12''
Two Clif Designs CD120W 12''
Two MA Audio MA120QS 12"
Two Elemental Designs 13Kv.2's
6 Elemental Designs Eu-700's
One Kicker L5 15''
what are you going for sq or spl? i would drop the l5 the ma and the ed right off the bat. if it had my choise i would be the pioneer the hifonics or the jl but its dependent on sq or spl
BigMack6933
I seen a video on ROE.com and this guy had two W0 12''s i think and the roof flex and door flex was insane and he said it only had 100rms going to each, and if thats true.... then the Jl would be nice cause i wouldnt be spending 500 on amps to get good perforamce... I want it loud, if it sounds bad ported ill run em sealed. if did the JL i wouldnt run IB!
IB is a bad idea. sealed or ported is your best bet the jl's are nice the pionners are decent and the hifonics arnt bad.
BigMack6933
I might also consider the RE 12''s i think they are only 80each shipped.. I like that idea ALOT compared to 150 each for the JL, but if the JL will be significantly louder, i'll pay the extra. im upgrading from a pair of Infinity refrence 12''s and I was happy with those, my friend has an accord i just installed two W3 10''s and they where suprisingly loud
BigMack6933
Well out of those choices , vehicle, and install Idea what would you personally buy? for just daily SPL, listen to rap mainly
well im partial to pioneer but the jl subs are really nice for the money and the res are a good idea. it would be a tough pick. work on your amp selection and then pic a sub that matches the amp the best. also the hifonics you speak of are tought to blow up a team mate of mine is running 4 of them on 2 colloses 10000 watts. and has yet to blow one. those are damn good woofs for the price.
BigMack6933
Are those pioneer subs louder then the JL? what about the incriminator audio 187s, two 12''s? i have one lethal injection 12'' and it was pretty decent.. for the pioneers i was gunna use a audiobahn rack mount 800rms amp, if i got the JLs, i was gunna use a Viper 300.1 I think 150 to each of those should be enough... and for the RE 12''s i would prolly do a small 400rms audiobahn amp
BigMack6933
or I may use MA audio amps, they are on sale right now, and are usually affordable anyways, that way I can set up my front stage how I want to and rear fill.. and stay on budget
i would get nothing that says MA onit. you can get hifonics amps really cheap all over the place. The RE res get pretty loud and sound decent too. if you want something that will get really loud id suggest the RE sx. also roof flex and door flex isnt to hard to do i did it at 135 dbs which isnt to loud.
