amp and sub
05spectraSX
- Member
amp and sub
hi, i am going to buy a 800 watt cable for an amp and subwoofer. If an amp maxes out 800watts, does that mean that only 800 watts will go to the subwoofer too?
05spectraSX
- Member
no. it doesnt and i dont think you or anyone can tell how many watts a sub is getting by ear. here is a good way to check output on an amp multiply the voltage of your car 12.6 if the car is off or 14.4v if its on X the amout of amps on the fuse thats what it is capable of producing there is a way to check wattage with a dmm and a clamp meter if you have them i can tell you how. if an amp is rated at 400 rms its putting out 400 rms if a sub is rated at 800 rms its putting out 800 rms if its rated max u have no idea go by rms not max. the amp only puts out so much power for instance my MM4000.1 produces 4000 watts rms bridged at one ohm so the sub will get 4000 watts
05spectraSX
- Member
is there anyway to shut on and off an amp. like say you have a headache, and you don't feel like listening to thumping, but just the radio, can you shut the amp off? because i got a stock stereo so i can't electronically adjust. And the rms for the sub is 600.
plus if the package says an amp of 800 doesn't that mean that the output is 800?
05spectraSX
- Member
05spectraSX
- Member
