Question??
car_noob
Question??
Post by car_noob »
I Got 2 Subs And 2 Amps , Both The Subs Are The Same And So Are The Amps And I Was Wondering If It Is Possible To Hook Up One Sub To One Amp???????????
Scarrell
Post by Scarrell »
yes, what kind of box are these going in? it would probably be best to make sure that if you use a sealed box, that the subs are in their own chambers, because using different amps on each one, may cause problems.. while be the same amps, both of them do not put out the EXACT same amount of power, which can cause problems.. actually this should be a pre-caution in using any box.. but what subs/amps do you have anyway?
