William!!!!!!!!!!!!!!!!!!
how the hell do you do it? i cant make that little dumbass do more than some backflips and you get 10 times the score i do!!!!!!!!!!!!!!!!!!!!
I gave up on that game, I was happpy when I got a score of 10 once :)
joeyc
Post by joeyc »
I had the high score for a while, thought I was a bad ass!! but...not at that game :p
JC's Customs
lmao!!!
When I saw my name I thought it was going to be about the rat-squirrel.
OKAY OKAY, here's the secret:
Use the rails. There is this one along in the lower right wall. I start off, before landing on it, I do a nothing 360. I hit the rail and then stay on it until it goes to the lower rail. Keep the arrow key held left or right before the guy falls to the lower rail, you do a 180. Then as soon as you hit that lower rail, jump off with a 180 and a nothing. This will easily get you a 18,000 points. Actually like 24k, but it's kinda screwy and I can't figure out why it changes when you do the same tricks. Each time you do it, your amount of points goes down per trick (for that trick). Do all kinds of variations. If you do the above except starting with the kickspin thing, I've gotten 31k once or twice. I just use the otehr rails too with the other tricsk that are slower.
it takes a bit of skill to stop falling down.
This tip was brought to you by Miller, Jack, and Jose ... drivnk repsonsibly
veggie-man
Post by veggie-man »
may i ask what game this is?
It's BMX something in the arcade, a platinum member feature
i think it scores you different because i got pretty good at the tricks over the last week and even the trick you described only gets me like 8000 points....
hahaha, I just think you aren't doing it right. I'll have to find some program that records the screen so I can show you.
I finally found a desktop recorder thing. I'm glad I recorded this one :) You can see me doing a 41k point trick :D
http://megahurts4.servebeer.com/cac/bmxpark.rm
It's a real media file. I have two streams, one for 56k and another for high speed peeps. I'm not sure how well it will stream with more than one person streaming it.
link doesnt work but through trial and error i have managed to worm my way into second place so only like 180000 points seperate us now......
