Need opinion on an enclosure
Alright trying to make n enclosure here and figure out which way I want to go. Its an enclosure for a pair of 15" executions. They are in seperate enclosure, both around 3.35^ft after displacement. Now the thing is, I can not fit the ports on the same face as the subwoofers, it's just not going to happen.
Keep in mind this is in a Focus ZX3 hatchback, with no back seat. How should I put the subwoofers and ports? I was thinking the subwoofer facing the hatch and the port coming out of the top would like best, but do you think there would be a performance difference if I put the subwoofer on the top, facing the roof and the port blowing back towards the hatch? What do you guys think i should try?
Well if it wasnt already made and all I would say try to go sorta like a JL HO box.
Simply put: slot port to the front and add a baffle board.
I got a few ideas on how to do this and maybe improve/differentiate the design so its not a direct patent copy...
If it's a show car, and not all out SPL then i'd say ports up sub back. I mean..it's hard to make an SPL install look as pretty as a normal daily or SQ install. Subs are rarely ever centered and you have to fire them whatever way works best. In some installs.. side firing the ports work best as well..something else to consider.
