install time
install time
i was just curious how long it took other guys to install things.....lets say you had to do a hu and 4 speakers in a car....say a 2 dr. civic no dash kit needed, dont have to pull the door panels but you do have to pull the rear deck.................im talking a good job too, wire tie the harness, reinstall the interior trim and everything back the way it was......i dont want to say how long it would take me yet i want to see how far off i am from everyones times........
I do quality work, not fast work. I may not do it as fast as other shops, but I do better work. I figure that install, probably 2-3 hours.
Vindicate
Post by Vindicate »
me and my uber skills = 2.5 weeks at 12hr days
Ranger SVO
Post by Ranger SVO »
Most Hondas are not to bad, so I will also say 2 to 3 hours to do it right
2-3-4 for me just to be safe speakers and hu arnt that bad. diffrernt cars diffrent amout of time.
thats about where im at....im with you justin, i dont crank out installs real fast but when their done its done right.....i was just curious because i did a ford contour today hu and four speakers and i had to pull all 4 door panels and it took right at 3 hrs start to finish
i did an escort yesterday with stock sound but wanted sub and amp installed with trunck loc. had to drill fire wall so it took about 3-4 hours had to do drill ground and then had some issues with a bad loc so i had to switch it out.
I would say up to about 3 hours to do an install like that. And i dont install professionally (no im not trying to brag).
Speaking of installing, i hope everyone here solders and doesnt use wirenuts or just the twist and tape method...
for what tedd? usually i use butt connectors lil easier than soldiering and almost as strong
For everything. If i can get my soldering gun close enough to the wires in a dash, i solder those wires. I always use solder on the speaker connections too.
Plus, soldering doesnt take much longer if you have a decent gun...it should only take a few seconds to get the wire hot enough to melt the solder. And its stronger.
