Sub Not Hitting
Z71Zak
Sub Not Hitting
Post by Z71Zak »
I have a 12" Kicker L7 hooked up to a Pioneer 760 Watt amp. I had it hooked up to an 800 Watt Pioneer amp, but my friend blew that one so I am using my other amp. I hooked it up the same way as my last amp, but my sub isn't hitting with this amp. I am getting power through the power and remote wire, but not through the ground (checked with a tester). The light on the amp is coming on. Does anyone know what is going on? Thanks
Darthness
Post by Darthness »
check yoru RCA's and speaker wire.
- Keith
All I can say is check what Darthness said. Make sure your wire polarity is right.
Z71Zak
Post by Z71Zak »
If I touch a power tester to the ground wire, should it show that there is power running through it? I touched the tool up to the power wire and it lit up.
Darthness
Post by Darthness »
also make sure your ground is good.
- Keith
