Ok, my question is:
When your building ur enclosure to specs, and it says lets say, 1.5cuft of space inside, how do u take account for any type of sound dampening spray you apply to the inside - and what about bracing?
Enclosure Building Question
If your wanting to do a sound dampener inside of your box, look into something like hushmatt foam. I have heard of people getting really good results with it in the box. It will also make the box seam a little bigger to the speaker, same theory as putting polly fill in a box.
Either way, I wouldn't worry about the internal volume that much. The hushmatt is only about a 1/2 inch thick, so it shouldn't make your box seem that much bigger. If you go with regular sound dampening its normally only 1/8 of an inch thick or less. so the diffrence in internal volume wouldn't be that much either.
