need your expert opinion
hey experts i need your help im sure kiki would know this. I just bought that 15" MT for testing and to use as a back up woofer at comps. however its dual 1.4 ohm coils so if i run it down to .7ohm will my autotek mm2000.1D go into protect? and if so should i have someone mod it for me so it will? yea i know its one ohm stable but for a few seconds it should handle it i think. i dont want to buy a new amp. and i dont want to run the amp at 3.8ohm's as there wont be enough power. whats your reccomendations guys?
i think itll be alright alot of hifonics/autotek amps even crunch can run lower ohms. i have a couple crunch amps running around that is running 2ohms bridged. id give it a try and see how it does. just make sure you watch your gains. and if it gets really hot you might have to get a cooling fan for on it.
well its not under the plexi yet but it has 8 fans cooling the rack maybe ill cut the piece of plexi to fit loosely to cause it to create a cooling tunnel.sinister audio wrote:if it gets really hot you might have to get a cooling fan for on it.
any word on my bass knob light? as far as i can tell the knob still works but no status lights. the protect status light in the remote was out 2
Should be fine for short bursts of 30 seconds.
You will have to fuse it accordingly though....
Play with the fuses.
You will know when it draws past it, it will blow.
